Basement Support Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 07:25 PM   #1
basement support beams
how far apart do support beams need to be?
Trampers is offline   Reply With Quote
Old 03-14-2012, 07:29 PM   #2
Rewards Points: 4,454
depends on the beam size, span, & load to be supported,,, your architect/engineer has tables for this while your local bldg inspector has no clue - this explains why plans need a professional stamp - so the bldg inspector won't be on the hook when it falls down
The Following User Says Thank You to stadry For This Useful Post:
Trampers (03-14-2012)
Old 03-14-2012, 07:35 PM   #3
Experienced
Jackofall1's Avatar
Hello Tampers and welcome to the best darn DIY'r site on the web.
Now that a real good question, but a better is question is whats on top of the beam, or do you really want to know how far the post need to be apart, which leads back to the question what on top of the beam.
The farther they are apart the bigger they have to be.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Old 03-14-2012, 07:42 PM   #4
Hi thanks for the quick responses all, Let's see I have a bungalow and in the basement I want to move a support beam about six feet. the room is 18.5 feet wide. Right now the beam is smack in the middle of the room. What's above it....a hallway.
Old 03-14-2012, 07:58 PM   #5
seriously doubt you can receive a satisfactory answer from anyone on the forum other than consult a professional arch or engineer,,, this is a demanding project that calls for expertise from all incl the contractor
Old 03-14-2012, 10:55 PM   #6
Framing Contractor
Are you for real?
Joe Carola
Joe Carola is offline   Reply With Quote
Basement - Removing or moving support post jfgagnon Remodeling 12 08-08-2011 08:11 AM
support post at base of basement stairs tehya Building & Construction 5 03-31-2011 10:54 AM
Basement support post failure fetzer85 Building & Construction 15 05-09-2010 11:35 PM
support beams garnet Building & Construction 2 04-22-2008 09:08 AM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
