Basement Subfloor Refinishing - Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 12:52 PM   #1
Rewards Points: 12
basement subfloor refinishing - stairs
Hi there
Just looking for some advice on a project I'm about to start.
We bought a house with a "finished" basement where they put carpet and under pad directly on the concrete floor. Clearly this will have to go (I don't think its wise to put a sponge on a floor that might get wet - call me crazy.....)
Regardless of what which subfloor approach I use I will have to contend with the stairs. Its builders stairs right to to concrete so any subfloor will affect the rise of the last stair, probably more than the 3/8 inch allowed deviation by code.
I'd like to avoid replacement of the stairs. Any suggestions?
One idea I came across was to extend the bottom step into a 3 X 3 landing and then have the short rise from the floor to the landing.
Appreciate any helpful suggestions
montydog is offline   Reply With Quote
Old 08-22-2013, 06:36 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
should work, as long as the landing is at least the same width of the stairs in the direction of travel, and as wide as the stairs then it should be classified as a landing.
a check with your local building official should clarify it
good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-22-2013, 07:09 PM   #3
Rewards Points: 13,216
And some pictures would sure be nice.
Old 08-22-2013, 07:34 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by montydog View Post
Regardless of what which subfloor approach I use I will have to contend with the stairs. ... any subfloor will affect the rise of the last stair, probably more than the 3/8 inch allowed deviation by code.
Do you really see this as some sort of major problem?
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 06:33 AM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 10:13 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
