Basement subfloor recommendation for row house
as you've already determined, the short-term cheapest method's more wood on top of the dirt,,, both times 'cause you'll probably wind up doing it again,,, for REAL economy long term, use conc - do it right & do it once' is a good axiom for home repairs IF you plan on staying.
1 caveat to the previous post,,, if it were ours, i'd install a below-slab water intrusion system incl provision for sump, pump, & discharge line,,, worked in too many town/row houses & leaking bsmts are a nitemare - physically & wallet challenging,,, if you've got mold now, bang out the walls & check behind them, too.
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
