Basement Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 10:10 AM   #1
Rewards Points: 640
basement subfloor
well after trying dricore last year for 1/3rd my basement and HATING it, too nosiy, too spongy way too much work to level and costs way more, I am doing the rest of my basement with Plywood and XPS foam
I calculated this at under half the cost of dricore and a lot easier to do since I can do 32 sq ft at a time...
I want to put XPS foam down straight on the concrete, some people said glue it others said dont, not sure what is best here.. tape all the seams with housewrap tape.
put foamboard glue down so each plywood sheet is glued to the xps foam
put down a layer of plywood going the opposite direction so you have perpendicular overlapping seams
use flat head tapcon screws, not sure how many you need for a sheet of plywood I've heard as little as 10 and as many as 50 and no one seems to specify a spacing pattern or should the outsides be screwed leaving the inside alone, or do it like a drywall screw pattern?...
anyone have any advice on this?
BlueBSH is offline   Reply With Quote
Old 12-15-2011, 10:18 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Renting a Hilti gun or a Rochester ram set will be a lot faster then tap-cons.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-15-2011, 10:25 AM   #3
Rewards Points: 640
it wouldn't cause any issues with pulling the plywood into the xps or anything that would cause bumps? Screws you can torque down or out, never worked with a ram set before not sure what to expect in that area with this type of project?
if i went the ramset path i still am not sure on the number of nail down points
Old 12-15-2011, 10:42 AM   #4
Disabled wood vet
titanoman's Avatar
They have different caliber of loads to control depth. Then you just go bang bang bang. Make sure you wear ear-plugs, esp. in a basement. I'd probably put them every 18" or so.
Old 12-15-2011, 11:09 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Jheeeezh! FINALLY! AN HONEST PERSON WHEN IT COMES TO THE MERITS OF DRI-CORE.
Dri-Core has no merits.
XXX
Old 12-15-2011, 11:13 AM   #6
Rewards Points: 640
at first I thought it was a great idea, until I started putting it in, then that changed fast.... after a year with it, gag me
Old 12-15-2011, 02:23 PM   #7
Rewards Points: 640
anyone know if the XPS should be glued down to the concrete or should it just float? I've read contradicting things on that, but everyone says glue the plywood to the xps it seems like
Old 12-15-2011, 10:47 PM   #8
Registered User
Rewards Points: 5,514
No glue, just use t&g plywood or biscuit joint; http://www.buildingscience.com/docum...g-your-basment Unless carpet, then perimeter fastening for the stretch....
Gary
Old 12-16-2011, 10:14 AM   #9
Rewards Points: 640
Gary
Yeah I found that the other day and it just leaves me with more questions
The method in figure 1 is the one I've been looking into, but it says one layer of 1/2" ply fastened or two 1/2" ply overlapping with offset joints glued... but then the article says toung and grove ply, I dont know but I've never seen 1/2" plywood that is toung and grove unless I've missed it around here... usually dont see that until you get into the 23/32 range
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Suggestions for engineered wood over OVRX insulated subfloor in basement? MasonS Flooring 2 12-14-2011 08:59 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Basement sloping and subfloor install - question globus999 Building & Construction 2 06-17-2010 01:17 PM
Basement subfloor and Radon - ideas? globus999 Building & Construction 4 06-16-2010 01:38 PM
