Basement Subfloor?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2007, 10:21 PM   #1
basement subfloor??
I starting to finish my basement, right now it is a 1300 square foot room with a furnace in the middle. I am planing two bedrooms for the kids, washroom and a large rec room with a gas fireplace. I live in southern Ontario with fairly cold winters should I install a subfloor. My basement doesn't have any water problems. Has anyone used the Dricore subfloor system it look like the perfect solution but cost $7.00 for one 2 foot square. Any help or advice would be a great help.
thanks
master splinter is offline   Reply With Quote
Old 10-23-2007, 10:16 AM   #2
Rewards Points: 1,910
If your basement is dry I personally would favor a carpet over a nice thick closed cell carpet padding placed right on the concrete.
Be absolutely sure you have good egress windows in your kids bedrooms. There is nothing more important than that.
Old 10-23-2007, 10:40 AM   #3
don't use Dricore... it is too expensive for what worth... there are exact same (if not better) product which cost 1/3.... use the outdoor leak prevention plastic sheet then put osb on top... same material as dricore basically.... there is a web site for that but I kind of forget and too lazy to search for you... I did mine that way and cost only $800 bucks for 1000 sq. ft. basement.
Actually, didn't realize the poster post the thread twice, so here is the link again:
use product in this site rather than Dricore and you save $$
http://www.systemplaton.com/
KUIPORNG is offline   Reply With Quote
basement subfloor?? master splinter General DIY Discussions 28 01-22-2013 05:17 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
