Basement Steel Studs Gauge/width? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 02:43 PM   #1
Rewards Points: 83
Basement Steel studs gauge/width?
Hi,
My local home center sells 3 5/8" in 20 or 25 gauge, 2 1/2", and 1 5/8" in only 25 gauge.
I'm talking about saving inches in the room (which may not be worth it, I know) BUT is there a preferred width in the steel studs?
True a 2x4 is 3 1/2" wide, but if I can save space, why not?
Does the gauge matter for non-load bearing walls ?
I only have a choice between 20g and 25g in the 3 5/8" widths,
stuck with 25g in the smaller widths.
Is one easier to work with...cutting, screwing, etc.?
Also, I have heard only to use 5/8" drywall....will 1/2" work or be too flimsy?
Is there a preference if it is a perimeter wall (i.e. drywall on one side only)
Thoughts?
Thanks!
bergerdude is offline   Reply With Quote
Old 03-03-2010, 03:25 PM   #2
i would do full size for walling one side light gauge should be fine for non-loaded wall and i dont see why 1/2" would'nt work. use coarse thred screws
The older I get the better I was
Old 03-03-2010, 03:27 PM   #3
concretemasonry's Avatar
Rewards Points: 2,594
A wrinkled tin stud is a flimsy wall, so you definitely need the 5/8" drywall to stiffen it a bit. Dry wall on one side is definitely not as good as two sides, since the studs can twist/distort without something on the other side for stability.
Make sure you have the proper wood or other backup/reinforcement around openings for trim and doorsand wherever you want to hang anything more than an 8x10 photo.
Dick
concretemasonry is offline   Reply With Quote
Steel brackets on wall studs tns1 Carpentry 6 08-25-2009 06:52 PM
Steel studs / Basement Insulation Chemist1961 Building & Construction 9 06-26-2009 01:54 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Steel Studs ? Steve Carpentry 3 11-24-2006 05:10 AM
