-   -   Basement stairway landing require footing? (http://www.diychatroom.com/f19/basement-stairway-landing-require-footing-118148/)
Clutchcargo 09-23-2011 06:14 PM
63 Attachment(s)
I'll be building a new basement staircase starting this weekend. This requires a landing half way through the run. The basement floor is ~1" thick concrete. Should I cut out a section of the concrete and add a footing. This would support either a short wall or post?
Or is it OK to build this directly on the concrete floor
sixeightten 09-23-2011 06:19 PM
I can't see you cutting the concrete for this. If it seems solid, use a plate on the four sides and stud up to the landing. If there is any way to hang some framing from above, you could transfer a little weight this way as well.
Clutchcargo 09-23-2011 06:32 PM
63 Attachment(s)
I wish the floor were 3" thick then it wouldn't be an issue. With so little concrete, can I effectively attach fasteners to secure the plate or a post base?
sixeightten 09-23-2011 06:41 PM
I think you can. Use tapcons sparingly. Maybe cut a sheet of 3/4 treated ply the size of the landing and fasten that to the floor first with some PL 500.
Clutchcargo 09-24-2011 08:43 AM
63 Attachment(s)
That's not a bad idea. I didn't think of adhesive. I was trying to avoid the wood/concrete contact by putting some kind of membrane between the two. Maybe I'm overthinking this, I tend to do that.
The original staircase lasted more than 80 years built this way built right on top of the thin concrete
Gary in WA 09-26-2011 09:31 PM
To meet minimum Code may require footings under the thin slab to take the point loads at the posts. The landing requires enough framing strength to support 40# sq.ft., along with a few diagonal braces (or drywall) as it's elevated 4-5' in the air with bracing only from the stair sets direction. I'd build to minimum Code for the paper trail (handy when selling), and a permit if needed because you are replacing a structural element that may also be egress to/from the basement.
http://publicecodes.citation.com/ico...9_3_sec001.htm
Hit “next section” to read them all: http://publicecodes.citation.com/ico...011_par007.htm
Pictures, we like pictures……lol.
Gary
