Basement Stairs... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 09:43 PM   #1
Basement Stairs...
Hey, I got some great advice a couple months ago from here on how to frame along the stairs. Skirt board along the steps then 1/2" gap between the skirt board and wall framing for drywall clearance. I did exactly that and it turned out great. Well i finished framing and insulating that half of the basement and moved on to demoing the other half. Got all the old paneling and 2x2 framing torn out and this is what I found. The support beam is almost against the stairs . There is maybe just over an 1/8" space, just enough room for the paneling I tore out. What do you guys recommend for finishing this? Any input is appreciated!!
short1 is offline   Reply With Quote
Old 01-08-2013, 11:50 PM   #2
Rewards Points: 13,256
What's the plan for those nasty looking treads and rizers?
If there coming out and being replaced you could move the stringer over before installing new boards.
Old 01-09-2013, 01:33 AM   #3
A good cleaning and carpet is the plan for the stairs. The more i look at it the more i think I'm gonna have the beam protruding out of the wall.
Old 01-09-2013, 07:53 AM   #4
DIY staff
Rewards Points: 7,174
Lally column? I did not see a beam--Did I miss something?
Old 01-09-2013, 10:08 AM   #5
Yes, sorry, i keep referencing the lally column as the beam. However the beam runs along the top tread and is just as close to the side of the stairs.
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 06:33 AM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 10:13 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
