Basement Staircase - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 07:11 PM   #1
Talking
Basement Staircase
I am in the process of finishing my basement and want to open upthe staircase (to the 5th step). The staircase wall does not to appear to loadbearing (see picture). The load bearing wall runs the length of the basement(perpendicular to the floor joists). I wanted to get opinions on how to finishthe wall and what parts should be removed because there are two top plates. Anysuggestions or opinions would be greatly appreciated. Thanks!!
rubots12 is offline   Reply With Quote
Old 11-16-2011, 07:21 PM   #2
DIY staff
Rewards Points: 7,174
That should not be load bearing----is there a beam or girder down there?
Old 11-16-2011, 08:53 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,104
hard to say if that wall is bearing or not. sometimes the walls under doubled joists for stairwells are bearing walls but it depends on what type of joists are used and what is above being supported
its possible that is just a partition wall and the only reason the top plate is doubled is because of an odd stud length. sometimes stud lenghts are just slighlty more than what can be cut out of a 8 footer or a pre cut 92 5/8 stud so adding a second plate can allow for sticking with 8 ft studs to cut from as opposed to returning all the lumber and getting new studs
woodworkbykirk is offline   Reply With Quote
Old 11-16-2011, 08:55 PM   #4
There's a beam that runs the length of the basement centered in the middle.
Old 11-17-2011, 04:50 AM   #5
DIY staff
I'm betting that the wall is a partition---add a photo of the floor joists around the stair and the beam.
Old 11-17-2011, 06:23 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Post a picture of the underside of the stairs so we can see what happens to the stair support if the wall goes away.
Old 11-17-2011, 03:06 PM   #7
Rewards Points: 5,336
Remove all the studs back to where you want.
Reframe the area you want the balusters to rest on down to the floor.
You just can't touch the wall that is at the bottom of the stairs. The one with the joist hangers attached.
Ron
B. Franklin 1759
Old 11-17-2011, 05:14 PM   #8
Here's a few more pics.
Old 11-17-2011, 06:20 PM   #9
DIY staff
You are good to go!
Start work----Mike----
rubots12 (11-17-2011)
Old 11-17-2011, 09:12 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 284
It the next to last picture, isn't that a header the floor joist are hung to? How far is it to the next support for the header, if it is one? And if that is a header or beam what are the dimensions and length? Just askin
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 11-18-2011, 10:21 AM   #11
The floor joists are supported by the basement foundation and in the middle by the header. The header is approx 2x12 and just runs there in front of the stairs.
Old 11-18-2011, 10:34 AM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 284
If you remove one of the walls what will hold one end of the header up?
Jim
Old 11-18-2011, 05:25 PM   #13
There will be a couple of posts.
Old 11-18-2011, 06:43 PM   #14
Ole Wood Worker
BigJim's Avatar
Rewards Points: 284
Sounds like a plan to me.
Jim
Old 11-19-2011, 12:34 AM   #15
Registered User
Rewards Points: 5,460
It appears you have only one joist on each side of the stair well. Measure the remainder of the space next to the well joist, if 1/2", good to go. If 2", I would not remove the wall section without first adding a double joist on the side wall, spanning the new opening-nailing it to the existing. It may support the stair wall above, possibly a point load also- from the first to second floor? Check in the attic for any point loads- purlins and struts- bearing on the side wall, if not- the single joist will support the new opening.
Both pics appear to leave the 2" on top the wall plates, unless my eyes are wrong...
Gary
Tags
basement , framing , load bearing , staircase
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
