Basement Stair Riser Height Variation W/ Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 04:21 PM   #1
Basement Stair Riser Height Variation w/ Subfloor
Hello Ė Iím in the earlier stages of planning a basement remodel and have a question about stair requirements. I plan on using Dricore subfloor (7/8 in) and then an engineered hardwood (3/8 in + underlayment). So Iím anticipated raising the existing floor roughly 1.5 inches.
If that is done the existing rise on the bottom stair will no longer be within 3/8 of an inch variation. The obvious solution is to re do the stairs, but Iím wondering if anyone has any alternate ideas.
Iíve read some posts where people propose spreading it out into multiple stairs by using spacers. However, when I read the code, it appears that the largest and smallest need to be within 3/8 of an inch of each other. Some posts indicate itís only 3/8 inch from the stair before.
Any other ideas? Thanks!
BSponz1 is offline   Reply With Quote
Old 11-08-2012, 04:59 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
code is typically for new construction. You're not constructing new stairs .....
I would call the building official and ask them what you have posted here, then you'll get the correct answer from the person that will be performing the inspection
make sense?
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
user1007 (11-08-2012)
Old 11-08-2012, 07:05 PM   #3
Rewards Points: 6,652
Are the stairs being replaced with hardwood treads and risers, from existing pine board open riser stairs?
If they are, you will just work in the variance of height into your rise for the new stairs. If the existing are being left, you would just have a lesser height to/from the first tread.
Suggest doing a mock of the floor with some 3/4. ply to equal the new height, so you can see what it will look like.
Old 11-08-2012, 07:50 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
the variation shim blocks your talking about will only vary by about 1/8" from one tread to the next.. overall there can be a big differnce between top and bottom.. their making things work so you dont trip.. unless you want to build a whole new set of stairs
woodworkbykirk is online now   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
basement subfloor?? master splinter General DIY Discussions 28 01-22-2013 05:17 PM
Obnoxiously low basement ceiling height....Finishing basement. bustedstuff88 Remodeling 19 08-23-2012 10:04 PM
Basement subfloor or not? Master-o-None Flooring 2 12-01-2007 07:38 AM
basement subfloor?? master splinter Building & Construction 2 10-23-2007 10:40 AM
