-   -   Basement Stair Fininshing Advice / Skirt Board (http://www.diychatroom.com/f19/basement-stair-fininshing-advice-skirt-board-55737/)
DoubleK 10-22-2009 08:16 PM
3 Attachment(s)
Hi all first post. I am in the process of finishing my basement, and would like to finish my stairs. Ideally add a skirt board, and carpet. I am struggling with the best method to do this. My existing stairs do not have a gap on either side to insert a skirt board, should I take down my stairs, trim 2 inches off each tread and reassemble and put back up? Or should I Cut / notch the skirt board to fit (stairs are not perfect) Any advice would help. Thanks K2
bob22 10-23-2009 08:48 AM
I'm no carpenter but two thoughts:
1. Current stair treads have a fairly sharp edge at the step edge. Might cause wear-through on carpeting over time. You could install risers on the face of each stair with a rounded edge to fix this issue as well as give you a riser.
2. Potential problem with suggestion 1 above is tread might be too narrow once you add on the riser; someone on here or elsewhere can give you proper tread/riser dimensions.
