Basement Span Without Support? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 06:32 PM   #1
Basement span without support?
Hi there
I am thinking about doing a basement, and just wanted to know how big I can go before I need to put supports in?
Thanks Russell
Russell8 is offline   Reply With Quote
Old 11-29-2010, 11:40 PM   #2
Rewards Points: 1,092
Over 100', if you want to. The longer the span, the higher/beefier the supporting member needs to be. It all depends on how much height you are going to sacrifice for the beam, truss, or whatever it takes for your load. You will need to specify what loads you have, first.
Old 11-29-2010, 11:49 PM   #3
jlhaslip's Avatar
Rewards Points: 1,578
I've done floor systems at 40 feet wide with no basement supports, but the Owner works at a Mill that build LVL, so he supplied them.
The house was single floor only. No point loads on main floor.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-30-2010, 12:07 AM   #4
STRUCTURAL
No limit
The limiting factor is cost, otherwise any span without supports is engineering-wise feasible.
To come up with cost first you need it designed and then ask contractors to give you cost estimates on the design. If it doesn't fit your budget go back to drawing board and redesign it with smaller spans.
ENGINEER10 is offline   Reply With Quote
Old 11-30-2010, 03:50 PM   #5
Hi there
Well the span is going to be 12x12 metres and the ceiling is about 8 foot high,
The Following User Says Thank You to Russell8 For This Useful Post:
ENGINEER10 (11-30-2010)
Old 11-30-2010, 03:55 PM   #6
Get it engineered or call your building supply and see if there's a take-off person that can calculate the loads. I used to be that guy many years ago and it's not rocket science
mrgins is offline   Reply With Quote
Old 11-30-2010, 04:08 PM   #7
STRUCTURAL
Originally Posted by Russell8 View Post
Hi there
This is a 40' span.
12" or 14" Light-Gauge steel joists will easily and economically work with no intermediary supports.
Old 11-30-2010, 04:53 PM   #8
... or standard roof trusses, if you don't want steel. 12 metres is no big deal. j
Old 11-30-2010, 09:49 PM   #9
STRUCTURAL
A basement does not have a roof, therefore trusses are ill advised.
Old 11-30-2010, 11:11 PM   #10
Sorry for not specifying. A flat truss is essentially a BCI/TJI. Yes, a typical A-shape would make the second floor navigation a bit awkward.
Old 12-01-2010, 05:43 AM   #11
Framing Contractor
Those are I-joists, not floor trusses.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-01-2010, 11:39 AM   #12
STRUCTURAL
These would have to be 3 feet deep trusses spaced 12" on center.
That's much more expensive than 14" metal joists.
Old 12-01-2010, 03:23 PM   #13
Yes, a flat truss is not a I-joist, but they are essentially the same animal. Rectangular, set "on edge", etc. I have no idea of the relative expense of a flat truss, nor do I know what he is putting on top. Just another option to look into.
Basement - Removing or moving support post jfgagnon Remodeling 12 08-08-2011 07:11 AM
No support beams in basement? Rattlinggourd Building & Construction 17 07-19-2010 10:10 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 08:55 AM
