Basement Soffits And Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 03:45 PM   #1
Basement soffits and ceiling
I followed the advice I received after searching but it didn't seem to work.
I am creating soffits around my duckwork and steel beams in my basement. I tried to use a powder acuated gun to shoot right into the steel when attaching the wood, and this didn't work at all.
What do you do?
Also, can I just attach the drywall to the bottom of the 1st floor joists? Or should I run 1x2s perpendicular across for a uniform distance? I would rather not lose the headroom though.
Thank you!
wesley8808 is offline   Reply With Quote
Old 07-28-2010, 06:39 PM   #2
DIY staff
Rewards Points: 7,174
Second question first---Sure you can attach the drywall directly to the bottom of the floor joists--
Most people aren't that lucky--often a 2x2 is nailed to the bottom of the joist in order to clear conduit,pipe and wires.
Soffiting in a basement can be done many ways----a picture will get you the best help on that--
I use plywood or OSB and 2x2s--no framing---a picture is needed---Mike---Hope you can figure it out.
Snow in attic through mushroom vents,leaking into great room ceiling thom risley Roofing/Siding 17 02-03-2014 03:47 PM
Basement kitchenette pjpjpjpj Project Showcase 9 12-09-2010 04:02 PM
Building soffits around ducts/support vseven Building & Construction 1 08-13-2010 01:55 PM
Suggestion for framing around ducts/pipe in basement xuc318 Building & Construction 2 12-19-2009 06:07 AM
Is it advisible to insulate under a ceiling Karsten Building & Construction 2 12-13-2009 05:23 PM
