-   -   Basement soffits and ceiling (http://www.diychatroom.com/f19/basement-soffits-ceiling-77375/)
wesley8808 07-28-2010 04:45 PM
I followed the advice I received after searching but it didn't seem to work.
I am creating soffits around my duckwork and steel beams in my basement. I tried to use a powder acuated gun to shoot right into the steel when attaching the wood, and this didn't work at all.
What do you do?
Also, can I just attach the drywall to the bottom of the 1st floor joists? Or should I run 1x2s perpendicular across for a uniform distance? I would rather not lose the headroom though.
Thank you!
oh'mike 07-28-2010 07:39 PM
Second question first---Sure you can attach the drywall directly to the bottom of the floor joists--
Most people aren't that lucky--often a 2x2 is nailed to the bottom of the joist in order to clear conduit,pipe and wires.
Soffiting in a basement can be done many ways----a picture will get you the best help on that--
I use plywood or OSB and 2x2s--no framing---a picture is needed---Mike---Hope you can figure it out.
