Basement Slab Done Wrong - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 08:53 AM   #16
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Whether or not the floor was PERFECT - the fact that the basement floor is 5 freaking inches higher than it was supposed to be would be a dealbreaker for me. That's not even close to what you asked for. Ceiling height is a a premium in most basements - 5" is a LOT!
Based on the way you are describing this guy it doesn't sound like he is willingly going to come in and bust it up and do it over - may be time to lawyer up.
CoconutPete is offline   Reply With Quote
Old 08-16-2012, 09:46 AM   #17
Concrete & Masonry
Rewards Points: 582
I'm not sure how much help the inspector is going to be able to give you on this one, other than possibly re-assurance that the floor is "non-conventional" at best. As far as code, I can't imagine any state has a max. thickness or it's against code to pour 2 layers, even it it's a bad idea. Also unlikely you'll find any standard protocal for flatness of residential floors.
Any chance your blueprints have a cross section showing the proposed height between the finished basement floor and the bottom of floor joists? Or at least the finished floor height in relation to the existing basement floor?
jomama45 is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
2X4 Framing on sloped basement slab chobio Building & Construction 2 07-02-2011 08:11 AM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 08:17 PM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 03:20 PM
bathroom basement subfloor on concrete slab Gus72 Building & Construction 9 01-19-2008 05:57 PM
