Basement Shower And Mortar - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 01:03 PM   #1
Rewards Points: 93
Basement shower and mortar
I'm installing a angle acrylic shower in my basement. The base has adjustable legs to level but the directions indicate I have to use mortar underneath afterwards. Issue is they are not telling me anything except mortar. I was wondering if I should use concrete (sand mix only) or mortar mix for blocks.
Also any tips for installing a shower pan with mortar. My floor isn't 100% level but I leveled the pan with the adjustable legs.
simonb is offline   Reply With Quote
Old 06-29-2013, 01:45 PM   #2
Rewards Points: 13,712
Premixed mortar, the kind used for blocks is what there suggesting.
The mortar is not for leveling, it's to give the bottom of the pan 100% contact to support it.
Without it, it may crack from flexing.
I'd first lay down some 6 mil. plastic or tar paper.
Basement floor and shower pan benleef Concrete, Stone & Masonry 10 04-02-2013 08:20 AM
Basement Tiled shower pan drain question heinlein0311 Plumbing 3 10-26-2012 09:35 AM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 07:52 AM
New tiled shower won't drain; mortar in drain. catitudes Plumbing 5 03-29-2009 01:08 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
