Basement - Rigid Insulation/Extruded Polystyrene - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-16-2008, 02:24 PM   #1
I am planning to insulate my basement and rim joists with rigid/extruded polystyrene. I just found out about the foil-faced variety and was wondering if there is an advantage/disadvantage to using one over the other. Any help would be appreciated. Thanks.
BillW is offline   Reply With Quote
Old 12-16-2008, 02:51 PM   #2
Rewards Points: 392
The foil faced has high R value but isn't as easy to cut. The polystrene can be scored and snapped. I use a small hand saw and straight-edge to cut the foil faced.
rustyjames is offline   Reply With Quote
Old 12-16-2008, 02:55 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
Cut the rigid foam slighly small and seal the edges with the expanding foam that also works as an adhesive.
I pre-cut my foam small, foamed the rim joist/sill and others and then pushed in the rigid back to the rim joist while it was still sticky. Then I just used some fiberglass to fill the remaining void.
concretemasonry is offline   Reply With Quote
Old 12-16-2008, 03:52 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Most foil faced foam boards are iso-cyanurate foam which will have a slightly higher R-value per inch than extruded poly-styrenes. There are some foil faced boards out there that are expanded poly-styrenes. This is the bead board that looks like cheap beer cooler foam. They are generally cheaper, lower performance materials. Whatever you use, foaming it in place with a low ex foam is a good idea.
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 4 08-03-2013 10:07 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
polystyrene under basement pad billybarty Flooring 6 10-02-2008 04:16 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
