Basement Reno Subfloor Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 08:27 PM   #1
So, I am finishing my basement and I have put XPS insulation on the walls and am preparing to also place it on the floor and then put 3/4 inch plywood down as my subfloor before finishing. My question is... what kind of space do I need to leave around the perimeter of the plywood for expansion, if any?
Thanks for any help.
MCWolfe
mcwolfe6 is offline   Reply With Quote
Old 01-31-2011, 08:33 AM   #2
Rewards Points: 5,332
MCWolfe
I see this done on TV all the time and wonder what happens when there's a water issue. And there will be a water issue.
If you're really set on this, I would frame out all the wall on the concrete floor and do this system between the studs. This way you don't need to remove the walls if you get water on the floor. I'd leave a 1/2" gap all around.
Ron
Tags
basement , subfloor
Definition of a finished basement vs. unfinished hectorlopez Building & Construction 2 01-31-2010 08:31 AM
Housewrap for basement reno mashedthumbs Building & Construction 3 01-23-2010 12:31 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
