Old 08-08-2012, 09:26 PM   #1
Basement Remodel Door Question
I am in the process of finishing my basement. I am going to be installing the doors next and I have a question about the one door that leads from the finished part to the unfinished section. Do I just use a normal interior door like the other ones and do I need to add weather stripping or anything along those lines? There is a heating vent in the unfinished section. Any help would be great.
Thanks.
gabel8 is offline   Reply With Quote
Old 08-08-2012, 10:46 PM   #2
Depends, is there a way to shut off the vent and not heat or cool the unfinished area?
Is there a return air vent in that unfinished part?
If there's no plans to finish the rest of the basement, and it's not going to be heated and cooled, then I would think it would be best to install an exterier door with a threshold.
Old 08-09-2012, 06:02 AM   #3
The unfinished area will never be finished. However, there is a vent for heating and cooling.
Old 08-09-2012, 06:55 AM   #4
AHH, SPANS!!!
with just one vent down there you probably want to put in an exterior door. The one vent probably pulls air from the return upstairs so therein lies the problem, also the one vent is not enough for the whole downstairs.
hand drive is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Basement remodel, help with an efficient layout? (diagram incl.) Dave88LX Remodeling 1 11-10-2011 04:36 PM
Basement Remodel gabel8 Building & Construction 3 05-24-2011 02:19 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
