Basement Project - Grafton, MA - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 02:24 PM   #16
Trucon01's Avatar
Rewards Points: 510
Yea, I thought so too. If I'm spending thousands on refinishing my basement, I'd spend a little more to have some "overkill"
How many coats of Radon Seal did you apply?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 05-30-2012, 02:30 PM   #17
If there is one place not to be cheap, it is moisture control. It protects the rest of your investment
I applied two coats, did it in small sections about 20 feet of wall at a time. Sprayed on the water, looped back and applied the radon seal, and looped back again. You might be able to do a bigger section in one time, I had to move stuff around my basement to apply it.
cfsully is offline   Reply With Quote
Old 05-30-2012, 02:32 PM   #18
Trucon01's Avatar
Rewards Points: 510
Very cool!! Looks like I'm buying a 5 gal on Amazon tonight!!
Thanks for replying!!
Old 06-01-2012, 02:46 PM   #19
Trucon01's Avatar
Rewards Points: 510
For anyone else wondering about this, here is the response I got from Radon Seal about using Drylok after Radon Seal:
Q.
I'm just wondering if it would be OK to first spray on the Radon Seal and then paint over that with Drylok?
A.
RS: Correct. Apply RadonSeal first (according to instruction) then apply DryLok 10 days later.
Q.
Drylok may not penetrate as deep because of the penetration of the Radon Seal, but have you heard of this?
A.
RS: Not an issue as DryLok is merely a paint. Penetrates very little inside concrete. RadonSeal will act as a primer for DryLok.
Regards,
Dan Richards
http://www.radonseal.com
1-800-472-0603
Old 06-01-2012, 08:43 PM   #20
Rewards Points: 79
Check with drylock as well. They may say that it voids any warranty or that out won't adhere correctly.
eclark is offline   Reply With Quote
Old 06-07-2012, 03:56 PM   #21
Cfsully, im in worcester and glad i foundypur post. Ive been googling and your experiences will be closest to what i can expect climate wise. That being said, has there beem a noticeble difference after you applied radon seal now that its been a good while. Besides that crack i mean. The areas you sprayed a year ago.
Thanks for all the info and pics, everyone else here too. I think ill start tracking my prog with pics as well.
I wasrecently laid off so im going at this full speed ahead, if i learn anything usefull ill share too!
Msantiago is offline   Reply With Quote
Tags
basement finishing , basement floor , sealing
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
Basement Project ThunderCAT Project Showcase 26 03-09-2010 07:27 PM
Basement Project Newbie upinsmoke Introductions 1 03-01-2010 07:33 AM
How best to dehumidify basement? peleliu HVAC 0 07-27-2009 10:55 AM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
