Basement Project - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 02:17 PM   #1
Rewards Points: 640
Basement project
well my parents this week are getting a competely new foundation (yeah a whole new one) the basement was previously finished but had to be gutted to redo the foundation... so now it is 8" cinder block walls the old one was 6" I believe, it defintatly was not as deep... but anyways... what is the best way to finish the inside? I convinced them while the outside is dug up to have the company install 2" XPS foam insulation... so this is what I think they are doing... new brick, then water seal it with that black tar stuff, then put the foam insulation over that...
just to make sure the builder does this right, do you seal the cracks on external XPS foam like you do internally? or does the tar take care of that?
but the real question is how to finish the inside? since there is 2" of XPS outside, couldn't we just take some 2X4's and attach them to the concrete block with tapcon screws and use them as furring strips, then drywall over that? seems almost to simple of a solution
BlueBSH is offline   Reply With Quote
Old 09-24-2010, 09:32 AM   #2
Rewards Points: 640
no suggestions / comments?
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Basement Project ThunderCAT Project Showcase 26 03-09-2010 06:27 PM
Basement Project Newbie upinsmoke Introductions 1 03-01-2010 06:33 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
