Basement Project - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 12:36 AM   #1
Post
Basement Project
Hello, I've browsed this forum many times and found lots of helpful tips, and now I have a specific question so I am making a post.
First off the vital info:
Project: Basement Completion
House age: 3 years
So my parents recently had some quotes for the completion of their basement, and the prices totally blew them away, so I along with the help of some friends who have experience doing this have began planning.
My problem:
Right now there is concrete on the bottom of the wall (about 12 inches),
then there is super 6 insulation and a vapour barrier.
One of the guys who gave a quote said theyd have to rip down the vapour barrier, frame for walls infront of the concrete, re insulate, and put the vapor barrier again.
The other guy said they would just frame infront of the current vapour barrier, and just put some insulation on the bottom concrete area.
Which guy is correct?
Thanks for your help, it is greatly appreciated!
Pazouks is offline   Reply With Quote
Old 01-12-2010, 12:46 AM   #2
King Construction Inc.
very confusing question, doesn't exacatlly make sence... post some pictures and maybe one of us can help you
nking is offline   Reply With Quote
Old 01-12-2010, 01:06 AM   #3
sorry about that
here is an image
Old 01-12-2010, 01:19 AM   #4
jlhaslip's Avatar
Rewards Points: 384
is there a frame wall in the pink spot?
jlhaslip is offline   Reply With Quote
Old 01-12-2010, 01:20 AM   #5
I dont believe there is, as one of the contractors that came by mentioned that another option is to strap the studs that are above the pink and bring them down.
Old 01-12-2010, 07:53 AM   #6
ccarlisle's Avatar
That's bare minimum code up here, as far as insulating a basement wall goes. It suits the builder OK and leaves the basement 'insulated' - but does squat for the HO as it is not really liveable.
To turn your basement into a liveable space, that all has to come down and proper insulation, framing, air sealing and vapour management has been undertaken before you could do more with that space that store your beer making kit.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Tags
basement framing , insulation basement
Basement Project ThunderCAT Project Showcase 26 03-09-2010 07:27 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
My basement finishing project DIY4EVER Project Showcase 6 02-18-2008 09:21 PM
