Old 12-31-2012, 09:12 AM   #1
Basement posts for staircase
Hello,
I would like to replace an old post in the basement supporting the stairs (probably the basement stairs and main level stairs). I want to replace it because it seems to be in the wrong location and i would like more space in a tight spot.
It is supporting the stairs on a joist that is already supported by the main beam (see photo). I believe the post should be on the first joist that has been cut in order to have built the stairs.
My question is about the type of jack posts I can use to support the stairs. Do these have to be single structure posts or can I use adjustable telescoping (2 piece) posts? Any help, thoughts, comments would help me out greatly.
shorteared is offline   Reply With Quote
Old 12-31-2012, 09:16 AM   #2
Sorry photo is upside down
Old 12-31-2012, 09:27 AM   #3
Super Moderator
Show us the floor joists that that pole is holding up----and the beam that you mentioned--
Right now,that column is not very strong and needs help----
Old 12-31-2012, 09:27 AM   #4
Sorry
Old 12-31-2012, 09:30 AM   #5
Back up and take another picture so we can see the framing at the top.
That support under the post is all wrong, should have been a header between the floor joist so it was fully supported not just sitting 1/2 way on a stack of wood.
There should have been a footing under it all the way down to the ground.
With a longer coloum all that blocking could have been done away with.
Old 12-31-2012, 09:30 AM   #6
Super Moderator
They are right side up on my monitor--------
Old 12-31-2012, 09:39 AM   #7
in the photos below the post with the 2x8 braced together is holding a joist that runs from the foundation to the main beam which can see in the other photo that is held up by a properly used and placed beam.
The photo with the staircase support should show you the joists in question along with the staircase itself.
Basement posts for staircase-photo-10.jpg   Basement posts for staircase-photo-8.jpg
Old 12-31-2012, 09:51 AM   #8
here is another shot from the ground looking up. I believe the post should be on the joist beside the post to support it because that joist has been cut . the joist that the post is on currently runs all the way to the support beam.
Old 12-31-2012, 09:54 AM   #9
Super Moderator
That column is really important----the rim joist along the stair opening is supported by a single floor joist--and that post---without that post,right where it is--you will need to triple up the supporting ,single, floor joist---
That is a guess---you need someone with structural/framing knowledge to look at it---
Old 12-31-2012, 09:56 AM   #10
STAFF
BigJim's Avatar
My stars, I don't know where to start, you really need to get someone there to see that in person, you have more than just the post to worry about.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 12-31-2012, 10:11 AM   #11
Supports done wrong like that are the main reason most old houses have sagging floors all around the stairway.
Amazing it did not just pop out and tip over.
Tags
basement, post, stairs
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Removing posts in basement ? alecmcmahon General Discussion 7 07-23-2010 08:49 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 03:55 PM
