Basement That Is Only Half Dug Out Please Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 11:14 PM   #1
Question
Basement that is only half dug out please help
Thank you for taking the time to read this. I am purchasing a house that was built in 1945, I plan on enlarging the house due to the fact it is only 740sqft. The basement right now has a external bilco door entrance. With only a 5 x 10 ft area usable right now and the rest has retaining walls and just soil backfilled. I would like to open up the retaining wall on the 1/3 and 2/3 to make one large basement, I understand i will have to lay new footings possibly add steel , no big deal. My only question is, once i open the retaining wall and start removing the soil. are there going to be footings on the existing block foundation walls? I don't want to start this project and find out there is nothing below the block. When a block wall foundation is constructed is there always a footing to hold that wall in place? Please help
Ken
kleakak is offline   Reply With Quote
Old 07-26-2011, 12:54 AM   #2
Concrete & Masonry
Rewards Points: 470
As someone who constructs foundations and has done full underpins to homes in the past, I wouldn't exactly file this under the "no big deal" catergory.
Ken
You should find footings under the block walls. What you will likely also find is that the foundation walls are only deep enough to get below your locale's frost line. Here that would be 48", which is on the deeper end of the country, yet doesn't make for decent basement height...........
jomama45 is offline   Reply With Quote
Old 07-26-2011, 08:30 AM   #3
Rewards Points: 5,336
If you want an expanded basement, I would support the house and dig under it, removing everything that's there and put in the foundation depth you want.
Ron
B. Franklin 1759
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Running from outside service panel into basement ksl420 Electrical 0 03-21-2011 12:30 PM
basement half wall with window griffinst Carpentry 2 03-09-2011 07:23 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
