Basement Leaking In Spots With Heavy Rain - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 09:47 AM   #1
basement leaking in spots with heavy rain
There has been lots of rain basement leaking in lots of spots between floor and wall. tried flex seal not working. not enough water for sump pump. could we possibly try hydraulic cement ? any suggestions welcome and greatly appreciated.
swirlmid is offline   Reply With Quote
Old 05-04-2013, 12:11 PM   #2
Do you have gutters? where do they drain? Water will win all the time, need to remove source of water.
Hardway is offline   Reply With Quote
Old 05-04-2013, 06:31 PM   #3
Get your draining working to the best of its ability - gutters properly draining away from the property, you soil grading need to be going away from your basement. Getting water away from you basement wall is key.
sdoerr2 is offline   Reply With Quote
Old 05-05-2013, 02:41 PM   #4
Concrete & Masonry
Rewards Points: 530
You can try anything you want, but the odd's are it's all going to be short-lived. If you have water seeping through the floor-to-wall joint it's a strong indicator that the exagerated water table is higher than the basement floor. The only way to effectively cure this is to re-direct as much water away from the foundation as possible and/or lower the water table via a drain tile collection system.......
jomama45 is offline   Reply With Quote
Soffits leaking during rain storm Jim Ignatowski Roofing/Siding 7 07-16-2012 02:44 PM
Breaker tripping without load after heavy rain mikemcd Electrical 11 09-12-2011 03:43 PM
Leaking cinder block basement CatRN Building & Construction 8 10-03-2010 05:45 PM
Basement Toilet Floods Every Time It Rain Tmb9862 Plumbing 12 10-29-2006 11:16 AM
Moisture in walkout basement after rain storm dannox02 Building & Construction 2 01-24-2006 01:45 PM
