Basement Leak - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 11:08 AM   #1
Basement leak
Have a leak in my basement at the wall/floor joist. Only appears to be a foot or two (maybe less) wide. Is hydraulic cement the way to go? Realize I need to chisel a dovetail crack for the cement, how is this achieved in such a tight spot?
Atskodinski is offline   Reply With Quote
Old 11-22-2010, 08:43 PM   #2
Rewards Points: 4,796
you're much better off excavating outside, referencing the crack, & coating it w/fiber-reinforced asphalt roofing cement protected by an impermeable membrane.
hydraulic will leak again while permitting intruding water to penetrate to the depth of the crack
basement leak KD1 Building & Construction 4 09-24-2010 10:35 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Leak in basement from time to time. willowgirl Building & Construction 13 12-30-2009 07:32 AM
How to stop a leak in basement wall? Ammons Home Building & Construction 6 03-04-2009 01:24 PM
Leak into basement at bottom of Door deepstuff Building & Construction 8 08-19-2008 01:46 PM
