Basement Insulation - Yes Or No & Where? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 12:09 PM   #1
Basement insulation - yes or no & where?
Is it better to insulate just the basement ceiling, just the walls or both? We have an unfinished basement with garage and we heat it with a pellet stove in winter. The garage is not partitioned off from the rest of the basement. We have no insulation on the walls (cement) and only some of the ceiling is insulated with fiberglass. Some contractors have said it's better to do just the walls, but I assume that's only if there isn't a basement garage involved. Does anyone have any advice?
JudyU is offline   Reply With Quote
Old 07-22-2011, 12:59 PM   #2
AGWhitehouse's Avatar
If you "live" in the space then insulate the walls. If it's only for storage and occasional workshop type activity then insulate the ceiling and move that pellet stove upstairs.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-22-2011, 04:18 PM   #3
Registered User
Rewards Points: 526
I hope the ceiling is fire-code drywall already and garage area can stop any fumes/fire? With a sloped floor to outside car door or a drain as required by minimum safety Code?
Gary
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 09:11 AM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
