Basement Insulation / Vapor Barrier Questions - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 08:55 PM   #16
Registered User
Rewards Points: 526
Welcome to the forums, Paul!
You might notice the dates before you reply, I did that once, too. The Building Science sites are good, the air space is bad; no facers on foam board; http://www.buildingscience.com/docum...ts?full_view=1
No air space; http://joneakes.com/jons-fixit-database/743 Glad to have you aboard!
Gary
Old 02-09-2012, 09:11 AM   #17
Thank Gary!
Hey Gary and thanks for the reply.
Yeah, I did end up noticing the date afterwards. Oh well! Actually, the air space is not really an air space; 2x4 walls, 1.5 inches away filled with 2x6 batt insulation. I just couldn't find 2x6 bluwood studs. And the foil face dura is slightly more permeable than 1" rigid XPS, with the 2 layers being slightly less than the 1" but, again, slightly more than the 2".
Overall, it should allow for a good capillary break (as well as thermal) while still not being totally impermeable. The r-22 insulation is likely a bit overkill but I didn't want to leave an air space! haha
And I did use a gasket under my bottom plate, even though they say I don't need one. Better safe than sorry really.
mrpaulrenaud is offline   Reply With Quote
Basement floods and have some questions andyroo89 Plumbing 7 04-01-2009 05:50 PM
basement insulation CooperChloe Building & Construction 2 01-25-2009 10:12 PM
Basement renovation - insulation question Jack13 Building & Construction 4 03-01-2008 07:01 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
