Basement Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2008, 12:05 PM   #1
basement insulation question
I recently noticed some condensation around a basement window, was concerned about moisture considering I'm in a low lying area. I felt behind the finished wall and found insulation lying right next to the poured concrete wall. I think the insulation is causing a minimal amount of black mold starting. Should there be no insulation in there if my walls are pored concrete. Should I tear out all the drywall and and start new with sealing the wall and then put up new drywall with no insulation? Right now I don't think there's any kind of an air gap?
benp is offline   Reply With Quote
Old 03-24-2008, 12:29 AM   #2
If your insulation or drywall are wet, they will need to be removed as this will only lead to more mold. Is there no vapour barrier ? If so, it's needs to be sealed.
vammen2 is offline   Reply With Quote
Old 03-24-2008, 10:46 AM   #3
when you say vapour barrier do you mean plastic in between the insulation and the wall or do you mean an open area in between the insulation and the poured outside wall?
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement framing insulation question Bcoleman6 Building & Construction 5 03-21-2008 06:37 PM
Basement renovation - insulation question Jack13 Building & Construction 4 03-01-2008 07:01 PM
yet another insulation question bobbyhill Building & Construction 2 12-06-2006 12:01 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
