Basement Insulation: Drylok First? Advice Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 07:33 PM   #1
Basement Insulation: Drylok first? Advice needed
Looking to keep the heat in my house this winter (aren't we all). Doing some research found out the a lot of heat loss is through the basement. Question is should I put Drylok on the basement walls, block foundation, or just put the xps up? Also what is the minimum thickness I can get by with for the foam? Trying to keep costs low and still have something I can use.
whiteblur is offline   Reply With Quote
Old 09-27-2010, 08:17 PM   #2
Rewards Points: 4,586
law of diminishing returns applies to the insulation & the thickness depends on ambient temp inside & lows outside,,, insulation retards the rate of transfer,,, w/' drylock ' type products, do a moisture test 1st - you may find the water's inside condensing on the cold wall,,, personally, we never use it professionally no matter what the guy i the apron store sez ,,, don't go cheap & do it right,,, be a shame to have to revisit this work
Old 09-27-2010, 10:58 PM   #3
Rewards Points: 956
i have seen xps mentioned before on here-what is this stuff?
federer is offline   Reply With Quote
Basement wall insulation dandw12786 Building & Construction 4 07-15-2010 01:11 PM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 11:02 AM
Basement Insulation question tophercole Building & Construction 0 11-19-2009 09:01 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
Advice on closed cell/open cell spray in insulation 794613 Building & Construction 2 10-31-2008 07:56 AM
