Old 04-02-2010, 04:43 PM   #1
Basement Insulation/Building Science
Hi
The infamous "diaper"that's in my basement, well I can't find who manufactured it.
It goes to 6 inches above the floor, as explained.
I am planning to have half my basement unfinished storage, and leave the existing insulation up. The finished area's walls will be about 1/2-1" from the poured concrete (or existing diaper insulation depending on the answers below).
If the air space behind the finished space is contiguous to the unfinsihed basement:
1) Is it still better to rip down the diaper?
2) Does the fact that the wall ends remain "open" help any moisture/airflow problems or will it not matter?
Any opinions are appreciated, Thanks!
Basement Insulation/Building Science-diy1.jpg   Basement Insulation/Building Science-diy2.jpg
bergerdude is offline   Reply With Quote
Old 04-12-2010, 02:22 PM   #2
Anyone?
Old 04-12-2010, 02:59 PM   #3
I guess what confused me (not too difficult, really!)
is the article below...
http://www.swinter.com/services/docu...Insulation.pdf
It seems to say diaper insulation is "ok" but better with a 6" gap at the bottom for moisture diffusion.
Also, maybe I'm nuts for leaving air cycle behind the walls...that is to say have the storage/unfinished areas abutt the finished space.
Yes, a 1/2-1" isn't much space for air to travel, but shouldn't it let moisture diffuse?
Old 04-12-2010, 09:48 PM   #4
Sorry I cant answer your question but I can tell you that you might want to consider forwarding your question to building science directly.
Good luck.
Mudball is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
