-   -   Basement Insulation/Building Science (http://www.diychatroom.com/f19/basement-insulation-building-science-68168/)
bergerdude 04-02-2010 04:43 PM
2 Attachment(s)
Hi
The infamous "diaper"that's in my basement, well I can't find who manufactured it.
It goes to 6 inches above the floor, as explained.
I am planning to have half my basement unfinished storage, and leave the existing insulation up. The finished area's walls will be about 1/2-1" from the poured concrete (or existing diaper insulation depending on the answers below).
If the air space behind the finished space is contiguous to the unfinsihed basement:
1) Is it still better to rip down the diaper?
2) Does the fact that the wall ends remain "open" help any moisture/airflow problems or will it not matter?
Any opinions are appreciated, Thanks!
bergerdude 04-12-2010 02:22 PM
Anyone?
bergerdude 04-12-2010 02:59 PM
I guess what confused me (not too difficult, really!)
is the article below...
http://www.swinter.com/services/docu...Insulation.pdf
It seems to say diaper insulation is "ok" but better with a 6" gap at the bottom for moisture diffusion.
Also, maybe I'm nuts for leaving air cycle behind the walls...that is to say have the storage/unfinished areas abutt the finished space.
Yes, a 1/2-1" isn't much space for air to travel, but shouldn't it let moisture diffuse?
Mudball 04-12-2010 09:48 PM
Sorry I cant answer your question but I can tell you that you might want to consider forwarding your question to building science directly.
Good luck.
