Old 10-30-2009, 01:29 AM   #1
Default Basement insulation
I have been doing alot of reasearch on insulating my basement befor finishing. It seems the DOE is recommending xps on the block wall and then fiberglass batts in the framing? The info is a liitle hard to decipher http://www.eere.energy.gov/buildings...s/db/35017.pdf
can anyone way in on this or point me in the direction of additional legit info??
organick is offline   Reply With Quote
Old 10-30-2009, 04:43 AM   #2
Remodeling Contractor
this is one way to go. A better but more costly method is to use closed-cell spray foam insulation. What is important is to control moisture and build the wall so that it is allowed to dry when a wet condition occurs. Check out the articles at http://www.buildingscience.com and do a search on this site since many topics on this subject have been covered well.
Old 10-30-2009, 10:14 AM   #3
concretemasonry's Avatar
Location: Minnesota - Longitude 45.057 Latitude -93.074
Thoroseal on the walls followed by XPS on the block/Thoroseal walls. The thickness of the XPS is up to you and your climate, but the temperature of the soil behind the wall is always much higher than the outside air temperature in the heating season and cooler in the cooling season (it is a great and valuable temperature moderator).
If you choose to build a frame wall in front, that is OK. Use a pressure treated plate, but you can use untreated for the studs. The studs should be attached to the plate with nails capable of surviving the plate wood treatment chemicals. The space between the studs and the XPS is up to you, depending what you might be running in the wall.
I would never use fiberglass in a basement wall because of the ability to hold moisture and never dry out. I have seen too many "accidents" (slab leaks, plumbing leaks, floods, etc.) that will require removal of the fiberglass before the mold starts.
Consider what you are going to do about the floor, especially if you are in a cool climate, since it has a very large area (maybe more than the wall area) and the soil temperature of the floor is about the same as the temperature of the lower part of the wall.
Dick
concretemasonry is offline   Reply With Quote
Old 10-30-2009, 10:18 AM   #4
Thanks guys,
what do you think about the xps sytem of attaching the drywall to the xps?? Sound alot easier than framing walls too?? any comments about that??
thanks
Old 10-30-2009, 11:56 AM   #5
ccarlisle's Avatar
I have seen both the separate xps sheets in 2'x8' sheets where you use furring strips in between each sheet and the ready-made panels already incorporate the xps and the furring strips - but in both case, I'm pretty sure the drywall needs the furring strips to hold on to.
You don't need 2'x3' or 2'x4' walls to put up xps...but you do need some sort of support to put up walls with drywall.
ccarlisle is offline   Reply With Quote
Old 10-30-2009, 12:04 PM   #6
yeah i know you need the furring was just curious if anyone had used this system and if they liked it.
Old 10-30-2009, 01:04 PM   #7
ccarlisle's Avatar
Look at a product called "InsoFast"; same idea.
Old 10-30-2009, 03:35 PM   #8
I actually can't find the xps panels that use the furring strips.....anyone have the link??? there are no insofast dealers by me and i dont want to order a product like that with no dealer to deal with.
Old 10-30-2009, 03:55 PM   #9
Do you plan on putting in any outlets or cable in the walls? If so, the separate wall (2x3 or 2x4 framing) could be very handy.
Dick
Old 10-30-2009, 04:44 PM   #10
Dick
There are already outlest and switches mounted to the block wall. I can just cut around them. I know they will stick out a little but its not the deceiding factor.
Old 10-31-2009, 08:46 AM   #11
ccarlisle's Avatar
Owens-Corning are the makers of the furring strip xps sheets. Use the link at the top of this page...
Old 10-31-2009, 01:54 PM   #12
thanks, much appreciated.
More On This Topic
Your sunroom is could be sitting empty most of the time, because it's too hot in the summer and too cold in the winter. Your sunroom can become a place for year-round enjoyment with a few easy steps. Imagine it as a haven--a place to sit and read, eat or... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. On the sides of each side I want dirt to fill in there and I would be building up a wall in between the cinder block wall the dirt wall to keep the dirt and sand that I have back... Read More »
How to Frame a Wall
How to Frame a Wall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you how to frame a wall. When you measure to cut your 2 x 4’s, make sure that you measure your wall and then you subtract 3 inches for your top plate and your sole... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. However most of the building material that I will be using until I get the stud walls up and a exterior wall up and a roof over it could be expose to some weather without any... Read More »
Basement Insulation raulakh Building & Construction 2 10-13-2009 02:36 AM
Basement Finishing Question (insulation) JFParker Building & Construction 3 05-27-2008 10:58 AM
Some Basement Insulation Questions atilla137 Building & Construction 6 10-16-2006 01:57 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
