-   -   basement insulation (http://www.diychatroom.com/f19/basement-insulation-36695/)
CooperChloe 01-24-2009 09:53 AM
basement insulation
Scenario
  • I'm finishing off my basement. It's a small room (about 300 sq. ft.)
  • The furnace and sump pump have already been boxed off with studs.
  • The rest of the walls have metal furring strips, which the drywall will attach to later.
  • It's directly below our living room.
  • The basement is almost entirely undergound. The parts that aren't are adjacent to the garage and another room in the basement (split level).
Questions
  • Should I use insulation downstairs? Our area is rated for R11.
  • Can I get those blue or pink sheets or do I need fiberglass?
  • The reason I didn't get studs was because it took more room in an already small area. I figured some insulation (even if below R11) was better than none.
  • Would it be worth removing the metal furring strips and replacing with studs? This will be our new family room (tv, video games, etc.)
ryanh 01-25-2009 06:23 PM
Depends where you live, you must live somewhere with warm climate all year around. If you are concerned about space you could use rigid insulation(1.5",2", 2.5") to bring up your r value with min space.
jaros bros. 01-25-2009 10:12 PM
Studs are more preferable. You can run receptacles in them and mechanicals. You also need a vapor barrier in the basement. Insulation is a good idea but you can just butt fiberglass up against the concrete. Concrete is like a sponge and you'll have moldy fiberglass in no time. Foam is a better idea...closed cell, because it will insulate and create a vapor at the same time.
Josh Jaros
