Old 06-06-2007, 10:05 AM   #1
Default basement framing, walls parallel to joists
Hi all,
i am just getting started framing my basement walls. I have a few walls that run parallel to the floor joists. Lucky for me, most of them fall directly below a joist. Is it still a good idea to put blocking in between the joists where a wall runs parallel even if it lines up with a joist? I thought it may provide more area to nail the top plate, or am ijust wasting my time and should I just nail the top plate into the joist?
Thanks in advance for any help!
DIY4EVER is offline   Reply With Quote
Old 06-06-2007, 10:19 AM   #2
yummy mummy's Avatar
I did what you want to do, as I thought why should I put the blocking in, when I have the joist right there.
But then I realized I had no place to nail the drywall to, for the ceiling.
So I would put the blocking in.
I know it takes more time but I think you need to do it.
yummy mummy is offline   Reply With Quote
Old 06-06-2007, 11:12 AM   #3
Thanks for the reply Yummy. I had the same thoughts but wanted to see what others thought.
I also have seen your pics of your basement project! Very nice job! I hope mine turns out as nice. Are you at the point where you are installing drywall? I can't wait to get to that point but I know I should just take my time and do the framing, electric, and insulation properly and not rush anything.
Old 06-06-2007, 12:18 PM   #4
Yummy Mummy is right... but be prepare that, when you actually drywalling ceilings... you will still find spots you don't have support and need to put more blockings... I agree... blockings is kind of a pain to do...
KUIPORNG is offline   Reply With Quote
Old 06-06-2007, 01:12 PM   #5
Default diy4ever
I am not yet at the point of starting drywall. I just have
one more duct run to box in.
And some small electrical and then I will be ready for drywall.
Between, work, kids, home, hubby, I don't have the time that I really would like to have to finish the basement.
I started in the beginning of November.
I'm certain yours will look great.
Would love to see some pictures.
Old 06-06-2007, 01:14 PM   #6
Default kuir****g
You are definitely right. I have already noticed that there are places where I have to add some blocking for drywall.
Before I start drywalling, I am going to go through the whole basement and check to see if I need any blocking in place before I start drywall.
Old 06-06-2007, 01:58 PM   #7
if you don't mind not being perfect... I insert 1x2 plywood strips at the end of drywalls then screw at both drywall end rather than blocking in many places as short cut... it is not as good as blocking for solid backing but many times good enough...
Old 06-06-2007, 04:57 PM   #8
I don't mind not being perfect, but the problem is that I have no power saw to cut strips.
I only have a mitre saw. So I have no choice but to use 2X4s.
But thanks for the tip.
If I ever do this again, then I have to get myself a circular saw.
Old 06-06-2007, 05:08 PM   #9
you can buy 2x1 ply wood bars at HD.... but anyway... there are different ways...
More On This Topic
Remodeling, whether it is in the garage or in the house is a huge undertaking. One of the easiest projects is building a non-bearing interior wall. The tools are basic, as are the needed carpentry skills. The condition of the floor and ceiling will... Read More »
How to Frame a Wall
How to Frame a Wall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you how to frame a wall. When you measure to cut your 2 x 4’s, make sure that you measure your wall and then you subtract 3 inches for your top plate and your sole... Read More »
This is Rob McMahon with ExpertVillage. Now, with a framing gun, there is generally two different, two different types of nailing styles that you use. One is through nailing which is preferable in most situations because it gives you the most strength... Read More »
Ceilings in an older house can be unsightly. A relatively inexpensive way to solve the problem is to install ceiling tile. While you can attach ceiling tile directly to the ceiling with glue, it's easier to install furring strips and attach the ceiling... Read More »
What is an I-Joist?
What is an I-Joist? by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. Once we get this wall corrected whatever problems and however we can go about getting it corrected and then the next step in the next procedure is to be sure it is reinforce and it... Read More »
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 17 07-25-2008 06:59 PM
Spray foam insulating joists in basement? peethree Building & Construction 6 08-24-2007 09:21 AM
Framing new wall in basement civil_corruption Carpentry 2 02-12-2007 09:23 AM
Concrete walls on wooden joists stonehanger Building & Construction 3 11-24-2006 06:26 PM
"floating" basement walls? greg s Carpentry 2 03-04-2005 09:56 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
