Basement Framing Top Plate Obstacles - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 01:46 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 352
Originally Posted by hand drive View Post
this may seem odd but why not use large metal L angle pieces that sit/screw tight to the underside of joist and catches the wall plates and maybe even the studs of the wall. place studs so they are in line with the joists above and the L piece can come down onto stud. chances are it will only catch the plates though so a 6" L would give you 3" clearance above the plates and still go fully onto double top plates ... a 9" L would come down into the stud plane.
I thought the same only use a continuous piece of heavy flashing. This would give good backing for the drywall
The Following User Says Thank You to TheEplumber For This Useful Post:
hand drive (06-04-2013)
Old 06-04-2013, 07:54 AM   #17
AHH, SPANS!!!
Rewards Points: 1,166
maybe even sliding the wall forward enough to put a 2x2 on the top of the top plate that is positioned closer to ceiling height will work too along with the L angle.
hand drive is offline   Reply With Quote
Old 06-15-2013, 04:28 PM   #18
bryanp22's Avatar
Rewards Points: 288
Could I just not build the wall all the way to the ceiling in that section? Basically have the top plate just below the the pipes? Would I have attach the wall I'm framing to the block if it doesn't run all the way to the ceiling?
bryanp22 is offline   Reply With Quote
Old 06-15-2013, 07:12 PM   #19
Well being a drywall hanger for sometime now. I get alot of these questions asked. What do you want to do about hanging drywall around this support beam,post,cables,pipes,etc..
I seen you had over head pipes to as well. Are you doing a drop ceiling, if not are you lowering the floor joists below these pipes??
Pipes on the walls. I would simply build a wall right infront of them or pipes inside the wall with top/bottom plate nailed and call it done.
If your doing a drop ceiling, you don't have to worry about having your top plate of your wall fastened up against your pipes+floor joists. Just make sure your walls can't fold in or out. Also.... make sure you have a nailer in the corner on both sides or atleast ceiling side for your drywall.. Don't depend on wall side to hold it.
DukeLewis87 is offline   Reply With Quote
Old 06-15-2013, 07:33 PM   #20
bryanp22's Avatar
Rewards Points: 288
I'm leaving ceiling exposed and painting it. Does that change anything? What do you mean fold in or out? I was going to do 1" xps with framing up against it
basement framing and insulating questions around ledge khatz Building & Construction 8 01-02-2012 01:50 PM
Replace basement sill plate Bcoleman6 Building & Construction 7 01-15-2011 11:01 PM
Another basement framing thread fbaggins Remodeling 3 07-08-2010 12:48 AM
Basement Finishing/Framing-Bottom Plate fluffie Building & Construction 6 02-15-2008 09:06 AM
Basement 2x2 furring strips, basement clutter, top plate not attached to floor joists touchsuhas Remodeling 5 12-26-2007 07:01 PM
