Basement Framing Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 11:28 PM   #1
Rewards Points: 462
Basement framing questions
Hello all!
Going to be taking on finishing the basement in the near future. As I'm in the planning stages I have a couple questions.
Some framers put down a PT bottom plate and then place an assembled wall frame on top of it while others use just a single PT bottom plate with the studs nailed right to it. Is one way better than the other or is it just a matter of personal preference?
Where the bathroom is going the duct work hangs below the beam:
The underside of the duct is at 81". With framing and drywall we'll probably be looking at 78" of clearance. A standard door frame requires about an 83" opening. What do you do for a door in this case? Cut a few inches off the bottom and don't let any basketball players use the bathroom?
Thanks for the help
Richo is offline   Reply With Quote
Old 09-15-2011, 07:00 AM   #2
Rewards Points: 5,336
The framing choice is yours. Before steel framing got so expensive and the new PT wood got so corrosive, I used to install the PT plates to the floor and frame with metal on top.
Before I'd cut the door, I'd look at moving the door to a different locaton, if possible. If there's no other choice, cut it.
Ron
B. Franklin 1759
Vent questions for basement barsink danielrg Plumbing 7 08-28-2011 02:33 PM
framing around drain pipe in basement griffinst Carpentry 5 03-25-2011 06:34 AM
Basement Stair Framing clemson726 Building & Construction 4 07-26-2010 05:09 PM
Another basement framing thread fbaggins Remodeling 3 07-07-2010 11:48 PM
Basement Sump Pump & Dimpled Plastic Membrane Interior Questions cloves Building & Construction 0 03-24-2010 09:44 PM
