Basement Framing Question, PT Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 04:11 PM   #1
basement framing question, PT walls?
Hello all,
I am getting ready to start framing a basement bathroom/bedroom, and I have a couple of questions. I am planning on using PT lumber on the 2 outside walls, and the green drywall on those 2 walls as well. I am coming off the block wall 2" to start the 2x4 walls, with 1.5" GPX ( I think thats what its called) and also leaving a 1/2" gap to allow for a air space, and to help getting the walls square. Also should I use a sill seal under the PT bottom plate for all the walls? Am I going overboard with using the PT lumber and green drywall? Thanks for the help!
brewcrew is offline   Reply With Quote
Old 08-27-2011, 04:31 PM   #2
Rewards Points: 5,336
Originally Posted by brewcrew View Post
Hello all,
There's no reason to use PT wood other then the bottom plate. Greenboard in the non wet walls in the bath. No reason to use it in the rest of the basement. If you're concerned about mold, put in the mold resistant board.
There are restrictions about bedrooms in basements. Multiple means of egress, ceiling heights , etc... If you pulled permit(s), you know.
Ron
B. Franklin 1759
Old 08-27-2011, 06:51 PM   #3
Framing Contractor
Hello all,
No reason to use pt on walls at all. Bottom plate only as was mentioned. Are you getting permits?
Joe Carola
Joe Carola is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Basement Insulation question tophercole Building & Construction 0 11-19-2009 10:01 AM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
Confused about framing old basement... please help. drunken0monkey Building & Construction 5 09-10-2009 03:19 PM
