Basement Framing - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 12:15 AM   #16
Registered User
Rewards Points: 4,912
If you use a vapor retarder/barrier sheet goods on the concrete, it could condense moisture from the basement air and mold the wood framing. If you don't put anything on the concrete wall, it will condense basement moisture. The best retarder is rigid foamboard, as said already, it won't mind being wet next to the concrete, long as it is air-tight from basement air. You can add an insulated (R-13) wood frame wall in front without worry of condensation if the foam is thick enough. At 68*F room air; 1" XPS and R-13 cavity= safe at/below 29%Relative Humidity above grade and 3' below grade (your frost depth). 1-1/2" XPS = 34%RH 2"XPS = 38%RH
Gary
Old 04-19-2013, 12:10 PM   #17
Rewards Points: 2,202
Yep Styrofoam glued to contact and sealed top and bottom. Then frame in front run your electrical and insulate.
Listen to Gary, answer his questions, he is good at this stuff.
mae-ling is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Basement Framing Help Captivating Remodeling 4 07-16-2012 08:19 PM
basement framing / insulation question in storage portion of finished basement. cobra5laddict Insulation 5 03-22-2012 10:59 PM
Basement framing: PT wood? ChrisWz Remodeling 9 02-24-2012 12:09 AM
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 01:06 AM
