Basement Foundation Outside Above Ground Is Shelling Off. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2008, 11:32 PM   #1
Basement foundation outside above ground is shelling off.
This is my first post.
My exterior basement wall above the foundation is shelling off badly.
What is the cause, and how do I fix it permanently?
Magicmann
Magicmann is offline   Reply With Quote
Old 03-06-2008, 03:56 AM   #2
ICF Construction
How old is the foundation? What is it's proximity to areas where salts are being used (Driveways in winter) or types of chemicals being sprayed on the lawn/garden abutting the foundation. This will help determine the cause.
With these answers you can nuetralize whatever is causing the problem and parge coat to give you a clean new surface.
Chris
Chris Johnson is offline   Reply With Quote
Old 03-06-2008, 06:12 AM   #3
Foundation problem
Thanks Chris.
The house was built in 1985.
Two years ago, I replaced the sod with lime stone and cement tiles. There is only 10 feet between houses.
The shelling started about 5 years before that the work was done.
I used the regular weed and feed when there was grass growing there. Weed and feed is now banned in Ontario Canada.
What is the best parging material on the market?
Magicmann
Old 03-06-2008, 06:58 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
shelling off = ?????
- Build Well -
Old 03-06-2008, 09:40 PM   #5
ICF Construction
Atlantic...Shelling off, same as spalling
Magicmann...use Durock basecoat (Durock allfacing, located in Woodbridge, ON) with fibermesh, what is you location, I can give you a local supplier
Chris
Old 03-07-2008, 04:54 AM   #6
My location is Richmond Hill.
What is the cause of the breakdown of the cement?
Thanks for all the help guys and a special thanks Chris.
Richard
Old 03-07-2008, 09:04 AM   #7
ICF Construction
Many things...
First thing to do is check and see if your foundation is one of the ones that was poured with sub-standard concrete and created a failing foundation...it was a major lawsuit in the GTA, check with Tarion or GTHBA for this info.
Could be improperly consolidated concrete (which I promise you was not done in the GTA on a subdivision type home) they back the trucks in, wet it up and let it flow. could be chemicals you sprayed, etc., etc. Unless there looking at it no one will know online the actual cause.
So check for substandard concrete as above, if that isn't the issue then you will be fine. Since your in Richmond Hill just go over to Durock in Woodbridge they are N.E. corner of 400 & 7 just north of HD
Chris
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Foundation & Finishing Basement Question? Taipans Remodeling 12 01-26-2009 06:56 AM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
Ground in basement remodel Az Barber Electrical 9 02-17-2005 11:13 PM
