Basement Foundation
evidently they used a metal form of ' channel ' - you could cut a slot in the floor leading to the sump but, for best appearance, putting the std 4" ads corrugated hdpe pipe under the floor is the best appearing,,, possibly budget influenced the 1st decision.
it won't ' fix ' the problem of infiltrating water ( nothing does that but exterior wall waterproofing systems ) but it will resolve the water pooling on the floor & cover up the drain holes which were drilled into the various cells.
IF you have more than 1 company in town, it would be prudent to talk to more than just the original guy - good luck !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
