Old 11-11-2010, 10:21 AM   #1
Basement foamboard question
I have a dry basement, no leaks or water problems. Most of the walls have been sealed with duralock product for basements. (basement age is 10 years old, most of the paint is that old as well with no flaking or cracking)
My dad acquired about 50 sheets of 3 inch foam board which I believe was using in some form of roof construction perhaps. The boards are 8 ft tall and 4 foot wide. They have a paper glued to them on both sides that seems to have fiberglass in it.
My dad has suggested using this board to cover the basement walls. Of course the seams would have to be sealed. My concern is that paper that is glued onto the boards. Like I said I believe it's got fiberglass in the paper because it can cause some serious itching, but I wonder if it might asbsorb moisture from the painted cement walls.
I'm looking for anyone that might have information on what this product is and some opinions on the usage.
lostraven1972 is offline   Reply With Quote
Old 11-15-2010, 06:24 PM   #2
Moderator
I don't know about the board, other than with the facing it may cause condensation on the wall after install, depending on location. You may need vapor permeable: http://www.buildingscience.com/docum...gs?full_view=1
Gary
Clothes taking longer to dry?
Question on basement wall/foundation height iub98 Building & Construction 6 07-15-2012 11:15 PM
Basement shower plumbing question. medicmike Plumbing 5 01-28-2012 05:40 PM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Basement sloping and subfloor install - question globus999 Building & Construction 2 06-17-2010 02:17 PM
