Old 08-05-2012, 12:48 PM   #1
Basement flooring suggestion help...
I am in the process of finishing my basement and I am to the step of installing a floor. I am going to be installing engineered hardwood and ceramic til in the bathroom. The 2 options I am contemplating are:
1. Delta FL with 1/2 inch plywood and then staple hardwood.
2. Radiant floor heating directly on concrete and then float hardwood over that.
I have a few concerns with both and hope that someone can offer some suggestions. For option 1, I have 2 concerns. First, I hate to sacrifice the height needed for the Delta FL and plywood sub-floor. Also, I have an unfinished section of the basement and it will be a significant drop off going from the finished floor to the concrete floor in the unfinished section. For option 2, I guess I don't know enough about the radiant floor heating and also, has anyone been happy with floating a floor over concrete?
Any help or suggestions would be great.
Thanks.
gabel8 is offline   Reply With Quote
water under laminate flooring in basement ladygryffin Flooring 2 07-28-2012 12:49 PM
Best flooring option for basement flooring bristo_99 Flooring 2 11-09-2011 10:59 PM
basement flooring Master Brian Remodeling 4 05-20-2009 10:50 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 03:38 PM
