Old 11-13-2010, 06:40 PM   #1
Basement floor without concrete???
Does building code allow a basement floor without concrete? For multiple reasons, I need to remove the existing concrete. I would like to install rigid foam to insulate, but then ceiling height issues cause problems. Can I install rigid foam with a OSB top, sealed between the 3" rigid and concrete walls?
tuscany is offline   Reply With Quote
Old 11-13-2010, 08:45 PM   #2
You can do anything you want, it's your house.
Not the best idea, though.
Ron
Old 11-13-2010, 09:21 PM   #3
concretemasonry's Avatar
If you worry about resale or codes, it could be a bad decision.
Many codes require the basement slab to have 3 5/8" contact with the walls to assure resistance to the slab sliding on the footing.
If you do not care, you can just pour the slab to the ceiling height you want and accept the facto you will have a small curb.
If you pour a slab, put down a 10 mil poly vapor barrier to help control humidity coming from the soil.
Dick
concretemasonry is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Help on removing concrete stairwell going into Basement. earthad1 Building & Construction 13 03-29-2010 02:59 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 03:55 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
