Old 05-21-2007, 05:08 PM   #1
basement floor water
The guy that moved into the house next to me claims that his basement floor is leaking from the bottom up??? he said there is no trace of any water that has been coming in from the walls and that the concrete is thin and porous enough to have water surface from under the house forming a puddle in the middle of the room. He reports that there are no leaks from the ceiling or anything, is this possible???
If this is possible, what are his alternatives of prevention? Dryloc, any other water based concrete water repellant?
bigboyjoel is offline   Reply With Quote
Old 05-21-2007, 05:46 PM   #2
A high water table and a poor or inadequate drain system and/or a broken sump pump will allow water to migrate through a concrete floor nothing short of repairing or installing a proper drainage will improve the problem.
Zero Punch is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 12 01-28-2009 01:09 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
