-   -   Basement floor steep slope against wall.. how to frame? (http://www.diychatroom.com/f19/basement-floor-steep-slope-against-wall-how-frame-89935/)
yohan 12-19-2010 06:28 AM
Hey there,
Hoping somebody can lend me some insight on my basement renovation.
I have it gutted, windows are in.. I should have asked this sooner but I have noticed that against the foundation walls there's a big slope inward, its about a 3/4 inch slop over approx 10" and then the floor is fairly level from there.
What are my options on framing on this very noticebly uneven surface? My bottom plate WILL have a gap on the middle facing edge ...
Is there a concrete planer that will work against the wall and only take off the high edge? it's a 46 foot length of wall I will be framing.
Joe Carola 12-19-2010 07:43 AM
Originally Posted by yohan (Post 553524)
Hey there,
Why will the plate have a gap? Can't you nail the plate on the angle and then cut the bottom of the studs on that angle?
stadry 12-19-2010 09:05 AM
like joe's idea ! you can rent scarifiers from major rental yards ( rsc - sunbelt - neff - hertz ) & get to w/i 1.5" of the wall,,, does leave a corduroy texture,,, apron store has diamond grinders w/dust shrouds - they also sell knee pads :yes:
yohan 12-19-2010 02:17 PM
that's a great idea, that is what I will do ... however originally I planned on putting dri core as a sub floor, not too sure now as this gap will create too much lift... im inspecting further and it appears as its just a low spot close to the side of the floor - much to my relief.
I'll do as suggested and cut the studs on an angle, much easier to deal with! thanks much!
gregzoll 12-19-2010 05:25 PM
I would personally get a concrete crew in to etch the surface with a cutting saw, so that a layer of concrete to level out the surface can be bonded to it. That would be the best way, or use self leveling cement.
