Basement Floor Plan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 03:13 PM   #1
Rewards Points: 640
Basement floor plan
Well been working on this for a while... came up with this general plan for the basement... what do you guys think?
BlueBSH is offline   Reply With Quote
Old 08-04-2010, 03:20 PM   #2
Rewards Points: 640
ignore the lighting as of how... that's not finished
Old 08-04-2010, 03:42 PM   #3
Old School
Willie T's Avatar
Isn't that an awfully tight kitchen entrance?
How come the door sits so far off the wall in the upper office?
Willie T
Old 08-04-2010, 05:37 PM   #4
Rewards Points: 640
This is just a rough sketch for now, lot of things are going to be refined over the next couple months not sure why the door moved so far up, must of nudged it when i was doing something else... the kitchen are will be smaller thats just a temporary cabinet set for show right now... need to talk to some cabinet guys about what would look best there for the space and the strange wall behind the kitchen that is empty space that is where pipes go from the upper floors into the foundation for sewage and such... there will be an access hatch on the one office to get to the cleanout pipe for it
Old 08-05-2010, 08:10 AM   #5
Rewards Points: 640
anyone know what clearances are required around a gas furnance and gas water heater? I find the ones listed in the manuals for them hard to believe.... the gas water heater says 1" on sides 2" on back and 2 ft on front...
Old 08-05-2010, 01:07 PM   #6
Registered User
Rewards Points: 5,498
Your LOCAL Code should tell you. Inside the furnace door is a clearances to combustibles. May need outside air source for gas units, or louvered doors. Check your County's web page for requirements. Don't forget the egress window or door required for basements: http://www.aacounty.org/IP/Resources...ementGuide.pdf http://illowaicc.org/uploadedFiles/I...20Openings.pdf http://www.pwcgov.org/docLibrary/PDF/005575.pdf pp. 4 + 6: http://www.codecheck.com/cc/images/CC5thEdSample.pdf http://www.codecheck.com/cc/pg19_20mechanical.html http://pdfdatabase.com/search/code-check-hvac.html
Be safe, Gary
Old 08-11-2010, 03:11 PM   #7
Rewards Points: 131
Nice plans Blue, what software did you use to draw it out?
HitLines is offline   Reply With Quote
Old 08-11-2010, 03:12 PM   #8
Rewards Points: 640
Cheif Architect
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
