Originally Posted by wizardofgore
I do have the alarm, I took it out to replace the battery. We have run the sump pump and it is working. Would a hydrolic cement be better to patch with? I can try to knock out what I did and redo it.
I re-read; if you bought the resurfacer I would think that would be fine (I'm no expert anyway).
Also, the "Basement Systems" drains do stick out; it is for connecting to their waterproofing wall system, I don't think its great. I have the same setup in my basement; although not installed as well.
