Basement Finishing Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2008, 10:53 AM   #1
Basement Finishing questions
Well Im on to my next huge project, I have tons of questions.
My basement is currently all block, we have the trench thing around the parimiter with the pumps incase water were to get in.
What do We seal the block with before we start studding?
Do we need to put the foam and plastic directly on the block after sealing?
Do we stud against that?
Then do we stil but in the pink insulation?
Do you recommend using the green water resistent or moiture guard drywall?
We are just getting started and have a bit of a musty smell, it seems though after we ripped out the old carpeting that it was from that. Also 1/4 of this basement was already (halfassed) finished. We ripped the drywall down that was up. It was installed with 1'lath directly to the block, unsealed, no insullation, no vapor or water barrier nothing, so the dry wall was molded a bit on the back side, from the natural moisture seeping thru the block.
Any advise, direction and products would be GREAT.
Thanks so much.
My husband thinks leaving a few inches from the block then starting the walls would be best, I think its a waste of space and just room for moisture to lingure.. What is the sence. either way it can be moisture blocked, he is thinking it will not be able to ge tto the wall then... Sorry but I think in this case Woman knows best...
Thanks again
Shanon
Demochick is offline   Reply With Quote
Old 09-25-2008, 11:03 AM   #2
Wow all these views but no one wants to help...GREAT THANKS
Old 09-25-2008, 11:34 AM   #3
yummy mummy's Avatar
Rewards Points: 1,016
I have been finishing my basement also, and you may want to check my posts and see if some of the questions you have may be answered there.
But, hang in there someone I'm sure will chime in.
Good luck.
yummy mummy is offline   Reply With Quote
Old 09-25-2008, 12:40 PM   #4
finished basement
Well I can only say how I did mine and that was put up the plastic. Then we used 2x4 studs so we could insulate, did the wiring plumbing etc. then dry walled. Look for any signs of moisture before you cover stuff up.
If your basement has never been wet your in luck. If it has had water or leakage find out why before you put thousands of dollars into it.
I only used green board in the bathroom in the basement for water protection.
Good Luck with the project--done right it will add value to your house. Done wrong will get expensive in a hurry if you get black mold!!
agrace is offline   Reply With Quote
DIY electrical work questions for finishing a basement. mac41099 Electrical 7 11-16-2007 07:59 PM
finishing my basement Questions handyman1355 Building & Construction 4 10-18-2007 09:03 PM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 08:28 AM
Finishing basement - electrical code ??? normwannabe Electrical 1 01-23-2006 07:48 PM
