Basement Finishing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 06:12 PM   #1
Basement finishing
I want to finish the basement in my home for more living area. My question is my home was built with engineered joists. I cannot figure out what to secure the top plate to when I start the framing. There is a 6" gap between the wall and bottom of the truss.
Trdnbsh is offline   Reply With Quote
Old 01-08-2013, 06:50 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
To the bottom of the truss cords. If running perpendicula to the truss and not under the truss, bridge the truss with 2x lumber.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
jaydevries (01-08-2013)
Old 01-08-2013, 09:58 PM   #3
oter pictures
Old 01-08-2013, 10:06 PM   #4
Rewards Points: 13,300
First time I've seen the cords just hanging in the air like that.
Why not just cut a block that's the lenght you need from the bottom cord to the wall then attach it with a 2x4 laying on top of the cord. Just predirll the holes in the cord so it will pull down instead of being pushed up as the screw goes in.
Trdnbsh (01-08-2013)
Old 01-08-2013, 10:12 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
Put a short 2x4 on edge along the side of the bottom cord- the bottom flush with the bottom cord- extend it to where you want. Your new top plate can now attach to it
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
mae-ling (01-09-2013), Trdnbsh (01-08-2013)
Old 01-09-2013, 08:41 AM   #6
Rewards Points: 1,444
Are those joists holding load if the bottom is not sitting on anything? Looks really odd to me.
mikegp is offline   Reply With Quote
Old 01-09-2013, 10:30 AM   #7
The house was built in 2012, so not sure if it is a new construction method. As far as I can tell the bottom cords are not holding any type of load but are ridged (no movement)
Tags
basement framing
Existing Basement Lights - Finishing Basement bergsj Electrical 6 01-04-2013 03:38 PM
Finishing my basement myself and have some questions boat21 Remodeling 2 09-20-2012 03:13 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
finishing a basement jimmyfloyd Building & Construction 2 10-21-2008 01:30 PM
